    (Amiberry) Problem with UAE files and the CPU Speed
    Emulator Arcade/PC/Console
    amiberry uae cpu speed
    3102
    • woodie
      woodie last edited by
      Hello there,
      I'm trying to create a UAE file for some games like Barbarian using this config: https://www.youtube.com/watch?v=fVjSod3j1hk
      But when I start the game, CPU Speed reverts back to 14 Mhz instead of staying at 7, as configured. All other parametres are ok.
      These are the contents of the file generated by Amiberry:
      config_description=
      config_hardware=true
      config_host=true
      config_version=4.1.0
      amiberry.rom_path=/recalbox/share/roms/amiga1200
      amiberry.floppy_path=/recalbox/share/roms/amiga1200
      amiberry.hardfile_path=/recalbox/share/roms/amiga1200
      amiberry.cd_path=/recalbox/share/roms/amiga1200
      ; *** Controller/Input Configuration
      joyport0=mouse
      joyport0_autofire=none
      joyport0_mode=mousenowheel
      joyport0_mousemap=right
      joyport0_friendlyname=Mouse
      joyport0_name=MOUSE0
      joyport1=joy1
      joyport1_autofire=none
      joyport1_mode=djoy
      joyport1_mousemap=right
      joyport1_friendlyname=Bensussen Deutsch & Associates,Inc.(BDA) Core (Plus) Wired Controller
      joyport1_name=JOY1
      input.joymouse_speed_analog=2
      input.joymouse_speed_digital=10
      input.joymouse_deadzone=33
      input.joystick_deadzone=33
      input.analog_joystick_multiplier=15
      input.analog_joystick_offset=-1
      input.mouse_speed=100
      input.autofire_speed=0
      kbd_lang=es
      ; *** Host-Specific
      amiberry.vertical_offset=0
      amiberry.hide_idle_led=0
      amiberry.gfx_correct_aspect=1
      amiberry.kbd_led_num=-1
      amiberry.kbd_led_scr=-1
      amiberry.scaling_method=-1
      amiberry.use_analogue_remap=false
      amiberry.use_retroarch_quit=true
      amiberry.use_retroarch_menu=true
      amiberry.use_retroarch_reset=true
      ; *** Common / Paths
      use_gui=no
      kickstart_rom_file=/recalbox/share/bios/kick37175.A500.rom
      kickstart_rom_file_id=C3BDB240,KS ROM v2.04 (A500+)
      kickstart_ext_rom_file=
      ide_mb_rom_file=:ENABLED
      pcmcia_mb_rom_file=:ENABLED
      flash_file=
      cart_file=
      ; *** Floppy Drives
      floppy0=
      floppy0type=-1
      floppy1=
      floppy1type=-1
      floppy2=
      floppy3=
      nr_floppies=0
      floppy_speed=100
      ; *** Hard Drives
      filesystem2=rw,DH0:DH0:/tmp/amiga/whdboot/boot-data.zip,10
      uaehf0=dir,rw,DH0:DH0:/tmp/amiga/whdboot/boot-data.zip,10
      filesystem2=rw,DH1:games:$(FILE_PATH)/Barbarian (Palace).lha,0
      uaehf1=dir,rw,DH1:games:$(FILE_PATH)/Barbarian (Palace).lha,0
      filesystem2=rw,DH2:saves:/tmp/amiga/whdboot/save-data/,0
      uaehf2=dir,rw,DH2:saves:/tmp/amiga/whdboot/save-data/,0
      ; *** CD / CD32
      cd_speed=100
      ; *** Display / Screen Setup
      gfx_framerate=0
      gfx_width=640
      gfx_height=256
      gfx_refreshrate=50
      gfx_refreshrate_rtg=50
      gfx_lores=false
      gfx_resolution=hires
      gfx_lores_mode=normal
      gfx_linemode=double
      gfx_fullscreen_amiga=false
      gfx_fullscreen_picasso=false
      ntsc=false
      ; *** CPU options
      cpu_speed=real
      cpu_type=68000
      cpu_model=68000
      cpu_compatible=false
      cpu_24bit_addressing=true
      fpu_no_unimplemented=true
      fpu_strict=false
      compfpu=false
      cachesize=0
      ; *** Memory
      chipmem_size=4
      z3mapping=real
      fastmem_size=4
      a3000mem_size=0
      mbresmem_size=0
      z3mem_size=0
      z3mem_start=0x40000000
      bogomem_size=0
      gfxcard_hardware_vblank=false
      gfxcard_hardware_sprite=false
      gfxcard_multithread=false
      rtg_modes=0x112
      ; *** Chipset
      chipset=ecs
      chipset_refreshrate=50.000000
      collision_level=playfields
      chipset_compatible=A600
      rtc=none
      ksmirror_a8=true
      pcmcia=true
      cia_todbug=true
      immediate_blits=false
      waiting_blits=automatic
      fast_copper=false
      ; *** Sound Options
      sound_output=exact
      sound_channels=stereo
      sound_stereo_separation=7
      sound_stereo_mixing_delay=0
      sound_frequency=44100
      sound_interpol=none
      sound_filter=off
      sound_filter_type=enhanced
      sound_volume_cd=0
      ; *** Misc. Options
      bsdsocket_emu=true
        Hello
        Sorry for my english
        But may be these informations to help you
        https://forum.recalbox.com/topic/16882/a-lire-emulateur-amiga-600-1200-amigacd32
        • OldGreg
          OldGreg @woodie last edited by
          @woodie : Have you try with a .lha file ? With .lha you don't need .uae files anymore. Maybe it can resolve your problem ?
          RPi 3B+ with Recalbox 6.0
          • woodie
            @acris Thank you for your reply, I created the file amiga1200.uae to test some options, but I don't know why it doesn't work. For example, "show_leds=false" doesn't change anything.
            @OldGreg Yes, with the latest update I download all my games in lha format. I tried with a clean install of recalbox and for some reason, my Amiberry doesn't override/read some options, when I launch games like Barbarian, Baby Jo, or Best of the Best, I need to push F12, change the options and then I can play as normal.
            I use the UAE to add values like "gfx_framerate" or "amiberry.vertical_offset". Both work perfectly, but like I said in my first post, I can't make a good config to play some games without going to the menu because the CPU Speed option reverts back to 14 Mhz.
              voljega Banned @woodie last edited by
              @woodie custom overloading is not really well working at the moment... wait a few weeks/months while we sort out any issue 😉
              • woodie
                @voljega Ok, perfect! Thank you guys.
