    On Screen Keyboard
    keyboard
    • Nicola Silveri
      Nicola Silveri last edited by
      ![alt text](![image url](0_1561498404833_photo_2019-06-25_23-32-29.jpg image url))
      i have 320x240 spi display and i see this virtual keyboard, is it a bug or can i do something to fix it?
      • Chriskt78
        Chriskt78 last edited by Chriskt78
        You are on RB 6.0 stable not 6.1 gpi public beta. Don't update after flashing the 6.1 image
        Nicola Silveri 1 Reply Last reply Reply Quote 0
        • Nicola Silveri
          Nicola Silveri @Chriskt78 last edited by
          @chriskt78 so i must flash 6.1 beta for fix it?
          • Chriskt78
            yes, if you are on a gpi case, it's only compatible with pi0
