    External USB storage for games: no systems error
    external usb storage systems
    • A Former User
      A Former User last edited by
      Hi everyone, I've a raspberry pi3 b+ with recalbox 6.0 and i decided to use an external usb Hard disk to store all my games and saves. I followed the guide https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN) but, when I try to copy games on the hard disk via network or directly from my PC with USB and start recalbox, a message says that there are no systems or game. 😞 Can someone explain this? Thank You!
      • RustyMG
        RustyMG last edited by RustyMG
        Apologies if this isn't exactly what you asked :
        I inserted my usb drive in the Pi, switched it on, and when it booted up, I simply went into the settings and changed game storage to external, shut the Pi down and put the drive in my PC to copy the files over.
        On your PC, if you do the usual "Windows key & E" to load up explorer, you will then see a folder on your drive called Recalbox, and inside that all the usual folders.
        Just chuck your bios files in the usual folder there, and ditto with the game files.
        And that's it!
        Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
        • ninjaw
          ninjaw Banned last edited by
          Recalbox does not share usb, however there is a fix:
          https://github.com/recalbox/recalbox-os/wiki/[4.1.0]-Sharing-a-external-usb-hard-drive-on-samba-network
          • A Former User
            Sorry but It doesn't work
              voljega Banned @Guest last edited by
              @melomitru can you describe what directories you have on your usb hard drive ?
