    Universal XML Screen Scraper Question
    universal xml scraper
    • RealAzyria
      RealAzyria last edited by RealAzyria
      i have a question about the Universal XML Screen Scraper, i've been using it for a awhile now, and i always do the mix so it does the screenshot, logo, and box art. now when it does the logo sometimes it doesn't look good. is there a way to do the Wheel Carbon instead? so i would have the screenshot, box art and the Wheel Carbon Logo. i probably know the answer (which is no) but it doesn't hurt to ask.
        Zing Global moderator Translator @RealAzyria last edited by
        @realazyria I do not know, I think not. But from what I know the "Universal XML Scraper" is no longer being updated, I recommend you use another tool for this purpose, I use and recommend the "ARRM" (https://forum.recalbox.com/topic/11850/arrm -another-recalbox-roms-manager), the "Skraper" is also quite famous (https://forum.recalbox.com/topic/13953/soft-skraper), but you can use any other of this link:
        https://github.com/recalbox/recalbox-os/wiki/Scrapers-(EN)
