    XINMOTEK XM-10 is not controlled by 1P and 2P.
    GamePad/GPIO/USB encoder
    xinmotek xm-10 controlled
    • rizzie
      rizzie last edited by
      Hello~ I use a nice recall box. I tried to apply XM-10, and it works well when 1P is set as controller. However if 2P is set, then 1P key does not work normally. Below is information about the joystick obtained with cat/proc/bus/input/devices.
      I: Bus=0003 Vendor=16c0 Product=05e1 Version=0110
      N: Name="xin-mo.com Xinmotek Controller"
      P: Phys=usb-0000:00:14.0-7/input0
      S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:16C0:05E1.0002/input/input6
      U: Uniq=
      H: Handlers=event4 js0
      B: PROP=0
      B: EV=1b
      B: KEY=7fff00000000 0 0 0 0
      B: ABS=30003
      B: MSC=10
      S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:16C0:05E1.0002/input/input7
      U: Uniq=
      H: Handlers=event5 js1
      B: PROP=0
      B: EV=1b
      B: KEY=1fff00000000 0 0 0 0
      B: ABS=30003
      B: MSC=10
      How can I use this information to make sure that both 1P and 2P can work properly?
      Thank you in advance, sorry for my English.
      • joss_baumont
        joss_baumont last edited by
        Try to remap 1P only. The two players should work properly.
        Recalbox 6.0
        Odroid XU4Q
        rizzie 1 Reply Last reply Reply Quote 1
        • rizzie
          rizzie @joss_baumont last edited by
          @joss_baumont Thanks a lot. It's very well working.
