    When I try to Use apt-get at command its not available - help ?
    command prompty
    • donal-mcmenamin
      donal-mcmenamin last edited by
      [root@RECALBOX ~]# apt-get update -sh: apt-get: command not found [root@RECALBOX ~]#
        RecalboxOS is buildroot system. This command is not availible https://github.com/recalbox/recalbox-os/wiki/Compilation-%26-Modifications-(EN)
        • donal-mcmenamin
          thank you - so will any bluetooth controller work without installing any additional software ?
            yes use bluetooth paring into emulationstation menu
