    Info input
    input
    • 0zzy
      0zzy last edited by
      Hi, i have configured my recalbox with
      mame.core=mame2010
      and
      neogeo.emulator=libretro
      neogeo.core=fbalpha
      I'm testing with a keyboard, so i have set up it as a controller throught the controller configuration menu. But i have seen neogeo coin are on right shift, start is enter key.
      Why not all emulators have the same key config? Is it a retroarch trouble? How can i reconfigure my neogeo setup key?
        voljega Banned @0zzy last edited by
        @0zzy keyboard as a controller are not supported in recalbox, use a real controller
        • 0zzy
          0zzy last edited by
          Hi @voljega you are right. With a common usb pad it works fine immediatelly with all these systems.
