    Trouble with KODI Web Access
    kodi sybu
    • hoddino
      hoddino last edited by
      I have an app that I've used with my Kodi install called Sybu Kodi. It works with no problem on my dedicated Kodi Pi, but in Recalbox I can't seem to get the Webserver options. Under Settings-> Service -> Webserver I see no options for ports or anything. Is this disabled in the Recalbox version of Kodi? I'd like to be able to use my app for typing, etc. Thanks!
      • digitaLumberjack
        Hi, you should configure your application to have the port 8081 https://github.com/recalbox/recalbox-os/wiki/Kodi-on-recalbox-(EN)
        • hoddino
          Thank you that worked perfectly!
