    Solved recalbox-boot.conf Dual mount points (HDD and Network)
    dual points hdd network
    2478
    • arcueid
      arcueid last edited by
      Hi all,
      I would like to set 2 share devices:
      • one device, to store roms, saves and system configuration
      • several network mount point from a media server
      I read this blog : https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)
      I can get one working at a time, but not both.
      Do you know why and how I can workaround this point ?
      Best regards,
      Alex.
      • arcueid
        Sorry, here is the conf file I'm using: https://pastebin.com/NTMafMkX
        • arcueid
          Hi,
          I there any solution to make this file mounting a device and network folders ?
          BR,
          Alex.
            OyyoDams Staff @arcueid last edited by OyyoDams
            @arcueid you cannot set 2 differents share devices (DEV and NETWORK)
            • arcueid
              Do you have any suggestion to use these 2 devices ?
                @arcueid that's not possible!
                • arcueid
                  arcueid last edited by arcueid
                  Anything planned for this support ?
                  How is PSX emulator with roms from 1GB Network ? loading isn't too slow ?
                  Edit:
                  Sorry, I think I'll keep System and Roms on the HDD, mounted thanks to recalbox-boot.conf.
                  On the other hand, I will request Kodi to find media from SMB shared folders:
                  https://kodi.wiki/view/Adding_video_sources#Adding_Remote_sources
                  https://github.com/recalbox/recalbox-os/wiki/Attendre-le-réseau-avant-le-démarrage-de-Kodi-(FR)
                  Thanks for the help so far. Now my main concern is the libraries crashing on Kodi start: https://forum.recalbox.com/topic/17659/kodi-crashes-after-library-scan/4
