    Wired XBOX One pad (Hyperkin X91) not detected
    GamePad/GPIO/USB encoder
    wired xbox pad hyperkin x91
    2189
    • radicldreamr
      radicldreamr last edited by
      I'm unable to get Recalbox to detect my two Hyperkin X91 gamepads. They are wired-only and work fine with retropie, (ONLY after updating xpad.sh module from source), but I don't like retropie. >_< I'm using the latest Recalbox 6.0 and I'm hoping this can be fixed.
        @radicldreamr said in Wired XBOX One pad (Hyperkin X91) not detected:
        Hello @radicldreamr
        We needs archive support with your gamepad connected.
        create archive support with http://recalbox/help or http//recalbox.local/help
        or
        https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
        • radicldreamr
          All right, my first time doing this so hopefully I did it right. Here's the support thingy you asked for: https://www41.zippyshare.com/v/f9pIo9tI/file.html
            @radicldreamr
            [    3.225255] usb 1-1.1.2.3: New USB device found, idVendor=2e24, idProduct=168a
            [    3.225263] usb 1-1.1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
            [    3.225267] usb 1-1.1.2.3: Product: Hyperkin x91 MegaMan Special Edition
            [    3.225271] usb 1-1.1.2.3: Manufacturer: Hyperkin Inc
            [    3.225274] usb 1-1.1.2.3: SerialNumber: 0000279BD0B1EA5E
            in recalbox.conf
            enable xpad driver
            controllers.xboxdrv.enabled=1
            ## Set the amount of controllers to use with xpad (0..4)
            • radicldreamr
              Well that is the first thing I did try. I enabled it again like you said, and it's still not detecting. I've made another output in case you need it, this time while xboxdrv was enabled.
              https://www117.zippyshare.com/v/uXn7Fh9j/file.html
              • radicldreamr
                And I understand that the internals say it detects my gamepads, but the controller setup screen says it doesn't detect any.
                • chicken
                  chicken last edited by
                  a solution ? the controller is still not compatible?
