    Recalbox 6.0 - Not able to save per-game shader presets in Retroarch
    Emulator Arcade/PC/Console
    recalbox 6.0 able per-game shader
    • vmman
      vmman last edited by
      Hi All,
      Does any know of a supported way to save per-game shader presets? I get an error in Retroarch when I try to do it via the Retroarch menu. I receive "Error saving shader preset:". I'm assuming the shader area is read-only, but I would like to change my shaders by game, especialiy remove shaders from Vector games, and set my favorite zfast standard and vertical shaders for my arcade games / per game.
      Thanks for the guidance!
      • FMO
        FMO last edited by
        Hello. Did the filesystem is writable ?
        mount -o remount rw,/
        (alt-F4 and then alt-F2 to reach terminal login screen)
