    PSX games are crashing
    Emulator Arcade/PC/Console
    are crashing
    • arcueid
      arcueid last edited by
      Hi,
      I've installed latest recalbox to my odroid Xu4.
      Some are getting hangs during execution (Need for speed 3), but it seems like ressources loading.
      But many PSX games are crashing : C.T.R., Crash Bash, Ace Combat 3, Soul Reaver, ...
      All Bioses are installed and correctly recognised by RecalBox.
      Does anyone knows where are located PSX emulator log files ?
      BR,
      Alex.
      • arcueid
        Hi,
        Here is latest es_log.txt: https://pastebin.com/y0gKEuc8
        And here /recalbox/share/system/es_launch* files : https://pastebin.com/R0xzM4Pb
        There is one issue with srm file, and pcsx can't create a folder.
        Which direction looks the more appropriate to investigate ?
        • arcueid
          Issue is the same with SCPH1001.BIN, scph5501.bin or scph5502.bin
          Roms md5sum:
          CTR - Crash Team Racing (E) (EDC) [SCES-02105].bin : 721fce296675c5a10922d6ffab86c73b
          CTR - Crash Team Racing (E) (EDC) [SCES-02105].cue : 5f177cab16f87e12c9020f889cafcffe
          I created the missing directory and learn that *srm files are for saving.
          Still no ideas of the issue yet.
          Here is the latest log:
          */usr/bin/retroarch -L /usr/lib/libretro/pcsx_rearmed_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/psx/CTR - Crash Team Racing (E) (EDC) [SCES-02105].cue
          running command: /usr/bin/retroarch -L /usr/lib/libretro/pcsx_rearmed_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/psx/CTR - Crash Team Racing (E) (EDC) [SCES-02105].cue
          Memcard 2: disabled
          Starting PCSX-ReARMed 6.0-DragonBlaze
          Running PCSX Version 1.9 (Apr 10 2019).
          Init new dynarec
          testing if we can run recompiled code..
          test passed.
          Mapped (RAM/scrp/ROM/LUTs/TC):
          80000000/1f800000/1fc00000/08000000/b1e14000
          found BIOS file: scph5501.bin
          RGB565 supported, using it
          plugin: plugins/builtin_gpu
          plugin: plugins/builtin_spu
          plugin: plugins/builtin_pad
          Plugins loaded.
          Loaded CD Image: /recalbox/share/roms/psx/CTR - Crash Team Racing (E) (EDC) [SCES-02105].cue[+cue].
          Track 01 (DATA) - Start 00:02:00, Length 69:56:02
          selected sound output driver: libretro
          CD-ROM Label: SCES02105
          CD-ROM ID: SCES02105
          CD-ROM EXE Name: SCES_021.05;1
          ari64_reset
          NI 9f75237a @800ac40c (800ac408)
          branch in delay slot @800ac418 (800ac408)
          Compile at bogus memory address: 830a8db4
          vi /recalbox/share/system/configs/retroarch/retroarchcustom.cfg*
            Hello
            version europe required sbi file.
            https://www.consolecopyworld.com/psx/psx_protected_games.shtml
            and your game strange extension CTR - Crash Team Racing (E) (EDC) [SCES-02105].cue[+cue].
            you need to control name file and extension.
            • arcueid
              Hi Acris,
              Thanks for the tip.
              I just had CTR running thanks to https://docs.libretro.com/library/pcsx_rearmed/#bios
              I will download *.cue and *.sbi for all other roms and check execution.
              Merci 😉
