    ES freezing and recalbox 6.0 stuck in recalbox screen
    6.0-dragonblaze
    • boxcarpilot
      boxcarpilot last edited by boxcarpilot
      I'm using a Raspberry pi3B.
      The ES is freezing when it tries to change on it's own the background music.
      When I reboot via ssh, the ES does not appear (it get's stuck in the recalbox screen (the one with white background).
      But I can hear the background music from ES. And the audio track keeps changing like normal.
      alt text
      The only way out of this is to
      Shutdown -h now
      And power on the raspberry pi again
        Zing Global moderator Translator @boxcarpilot last edited by
        @boxcarpilot I do not know what you did, but I recommend a clean installation of the latest official release:
        https://archive.recalbox.com/
        With a clean installation, the latest version, without modifications, is the same?
        boxcarpilot 1 Reply Last reply Reply Quote 0
        • boxcarpilot
          boxcarpilot @Zing last edited by
          @zing I will have to remove the custom music, aside from that it was a clean install
            @boxcarpilot Did you put a custom music? I had not understood that (probably because the translator was not perfect).
            Considering this, the problem is in custom music, read the Wiki:
            https://github.com/recalbox/recalbox-os/wiki/Add-Custom-Music-to-EmulationStation-(EN)
