    [SOLVED] Is there any way to sort the systems in the frontend?
    [solved] sort systems frontend
    • davmanypsp
      davmanypsp last edited by
      Hi, is there any way to change the order of the systems in Recalbox? In EmulationStation on pc It is possible to sort the systems editing the es_systems.cfg by just sorting them on that file.
        I guess it's quite the same. Couldn't test, but give a try ! It's in /root/.emulationstation/es_systems.cfg
        • davmanypsp
          You are right, it worked! But i have read that that file is overwritten whith the updates, so i have made a backup of it. Thanks!
            Updates can bring new systems, so you'll have to add them to your backup
