    Temporarily disable GPIO gamepad Retropie
    GamePad/GPIO/USB encoder
    temporarily disable gpio gamepad retropie
    • HenryBraxton
      HenryBraxton last edited by
      I built this using a Raspberry Pi 3. I have set it up to be able to be connected to a TV through HDMI and it turns the portable into a console. I have it set up to connect through Bluetooth to two PlayStation 2 controllers. My problem is that the pigrrl gamepad PCB (that is connected to the gpio pins) is always player 1. I want to be able to temporarily (and easily) disable the PCB gamepad so that I can play with just two PS2 controllers and the player 1 spot isn't taken by the PCB. Any thoughts?
      HenryBraxton 1 Reply Last reply Reply Quote 0
      • HenryBraxton
        HenryBraxton @HenryBraxton last edited by
        @henrybraxton said in Temporarily disable GPIO gamepad Retropie:
        guys my issue has been solved!!
        Nox VidMate Mobdro
