    PS3 controller some buttons not working on 6.0 rc3
    GamePad/GPIO/USB encoder
    ps3 buttons 6.0 rc3
    • jaume
      jaume last edited by
      Hi there,
      I'm using recalbox in a rpi2 and in the last update some buttons in my psx controller have stopped to work (square, X and circle). I'm using an usb adapter for both and recalbox are detecting them as ps3 controller but they are ps1 controllers instead. Somebody have a solution?
      Kind regards,
      Jaume
        Hello @jaume
        you use old version recalbox. Please update your version, and your problem must be solved.
        You need to define modem of ps3 controller.
        Check this tutorial : https://github.com/recalbox/recalbox-os/wiki/PS3-controllers-drivers-(EN)
        Edit recalbox.conf with winscp + notepad++ or via share network.
        Try bluetooth, official or shanwan driver :
        controllers.ps3.driver=shanwan
        controllers.bluetooth.ertm=1
