    Unsolved MAME Makes noise instead of proper sound, also Controllers don't work correctly
    Emulator Arcade/PC/Console
    mame makes noise instead proper
    • Spyhunter10
      Spyhunter10 last edited by
      Hi, i just added some games to MAME on the game station i built with recalbox. The games open fine, they look visually fine, but the controllers don't function and regardless which game i open, my speaker immediately starts putting out a horrible sort of i guess you could say white noise. Any help would be appreciated.
        Zing Global moderator Translator @Spyhunter10 last edited by
        @spyhunter10 Do a clean install of the latest version of Recalbox and try again:
        https://archive.recalbox.com/
        Did redoing the installation solve the problem? If not, what hardware are you using? Are you using the correct BIOS? Is ROMSET correct? Have you tried changing the emulator / emulation core?
        To avoid problems with Arcade games, read:
        https://github.com/recalbox/recalbox-os/wiki/Easy-Arcade-on-Recalbox-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Advanced-Arcade-on-Recalbox-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Check-your-roms-version-with-clrmamepro-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
