    8bitdo SNES30 Bluetooth input lag
    GamePad/GPIO/USB encoder
    9176
    • wtm001
      wtm001 last edited by
      I'm getting bluetooth lag when using my SNES30 controller. I'm comparing it to my buffalo snes controller and I can tell a difference between the two when playing Super Mario World 3.3.0 beta 17 This bluetooth dongle http://www.amazon.com/Kinivo-Btd-400-Bluetooth-4-0-USB/dp/B007Q45EF4
      • digitaLumberjack
        Hi ! Can you try to get closer to the recalbox (try 10cm between the dongle and the controller) and tell me if that changes anything. Next can you try with an other dongle from a friend or anything. If it changes the input lag, maybe we could add your dongle as a not compatible one in the compatibility list : https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
        • wtm001
          Thanks, I'll try this this afternoon. If it doesn't work, I'll purchase one of the recommended adapters and try it again
          • wtm001
            Purchased the Asus USB-BT400 Bluetooth 4.0 as recommended on the Compatibility page and started fresh and still had input lag. Wind up returning the 8bitdo controller and the bluetooth adapter. I'm currently using RetroUSB retrokit to use original SNES controllers and they work great, if you want to add that to the list. http://www.retrousb.com/product_info.php?cPath=21&products_id=44
            • pankratz
              pankratz last edited by
              I’m currently using RetroUSB retrokit to use original SNES controllers and they work great, if you want to add that to the list.
              Hello. I also wanted to use my RetroUSB-Controllers. But unfortunately they do not work with my recalbox. Any hints?
              • digitaLumberjack
                @pankratz 3.3.0 beta 17 ?
                • pankratz
                  Oh sorry: Yes! Current version beta 17 is running. I got a Kit I put in a SNES-Controller and a RetroUSB-adapter. Both work with my pc.
                  • digitaLumberjack
                    When you go to the controllers settings and try to configure a controller, when you press a button does it react ? Did you configured it ?
                    • pankratz
                      The system completely do not detect the controller in the controllers settings.
                      • pankratz
                        Is there any way I can help with further information? logfiles etc?
