    Clones and parents in fba_libretro
    clones parents fbalibretro
    • david-llort
      david-llort last edited by
      Hi, I have a question related with parents and clones. How can I load a specific clone? Can be merged with the parent one? For example, in fba_libretro, trying to play Vendetta, the parent (2.5Mb) is the WorldWide 4Players. But that means that there is no character selector, Player 1 always play the same character. So I got the WorldWide 2Players clone (0.25Mb) that obviously can't be loaded by itself (it needs the parent). But I don't know how to make it works. Copying the parent zip and the clone zip in the same fba_libretro folder create me 2 entries, but only the parent works. There is any way to "merge it"? Thanks
        voljega Banned last edited by
        Well it's strange, clone rom should work that way... expect if it's not supported by mame in the related version !
        • david-llort
          Yes, it was simply bad luck and using clones that weren't compatible with the bios. I tried so many clones that I though that I was doing something wrong. I found another clone and worked perfectly. Thanks
