    Solved Des difficultées a se connecter en wifi ?
    difficultées connecter wifi
    4250
      OyyoDams Staff @JRbaka last edited by
      @jrbaka écoute, ce n'est pas que je ne veuille pas t'aider, mais on tourne en rond... Il est techniquement impossible que Recalbox s'amuse à changer tout seul ce paramètre. Donc regarde de ton côté, et/ou donne moi un peu plus de billes pour t'aider, je n'ai pas ta Recalbox sous la main et ne suis pas magicien 😉
      lhari84 1 Reply Last reply Reply Quote 0
      • JRbaka
        @OyyoDams Oui pas de problèmes. Vous faite déjà un boulot extraordinaire
        Lorsque la prochaine version sera dispo je referait une installe a neuf.
        En tout cas merci pour ta patience et la clarté de tes informations
        Raspberry Pi5 4 Go
        RGB Dual
        Recalbox version 9.2.3
        Clé USB3 Sandisk 64 Go
        • lhari84
          lhari84 @OyyoDams last edited by lhari84
          @oyyodams
          Hi,
          I faced some wifi issues described in initial post too during beta phase.
          When I'm reading this thread now, I guess my problems will persist in RC, until switching from "US" to "FR". (I plan to test RC2 this weekend if it's released and I find some time).
          So my question is:
          Is there any disadvantage switching to region "FR"? It seems that many users are facing issues with default setting "US", why not "FR" or some generic european region by default?
          Another thing I want to ask, and I wasn't able to find in changelog unfortunately:
          Can I enable "System security" in RC(2) without breaking or disabling web manager? this was an issue in 4.1 versions...
          Thank you very much in advance for your answers and sorry for writing in english, but I'm not speaking french and use Google translator to read french posts 😉
          Pi 4:
          Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
          Pi Zero 2W:
          GPi Case 2W, Recalbox 9.0
            OyyoDams Staff @lhari84 last edited by
            @lhari84 Hi,
            You can take a look on this page: https://github.com/recalbox/recalbox-os/wiki/Wifi-country-code-(EN)
            So basically "FR" code has a larger range than "US" range, but because this is a standard and to be compliant with US authorities, US is the default.
            About the "system security" feature, my advice is you shouldn't enable it as it's bugged and has to be rewritten.
            100.3k
