    8BITDO SFC30 BT Connection
    8bitdo sfc30 connection
    • defi
      defi last edited by
      Hey guys, i am new to recalbox and the pi system i bought a pi2 b with the 8bitdo SFC30 gamepad and use the current beta of recalbox so the strange thing is, when i connect the gamepad with usb, everything is working fine. if i pair it with bluetooth the crosshair isnt working properly anymore (up/left/right works, but down is broken and does some other keys at same time) on my windows machine i dont have such problems with the pad paired with bluetooth. is there any work around or am i the only one with those problems?
      • digitaLumberjack
        Hi, try to reconfigure the controller in the recalbox menu (START + CONTROLLER SETTINGS)
        • defi
          defi last edited by
          ye only did it like 50 times now... i start thinking that the controller isnt really compatible with BT to recalbox os when i use it with usb its running perfect. also my xbox360 (usb) controller
          • defi
            defi last edited by
            nvm got it working. the controller had to be started with start+R
