    Can't launch games
    mame gpio game problem english
    • freddy00
      freddy00 last edited by
      Hello guys!
      I've recently setup my recalbox with 2 GPIO joystick and 3 buttons each (6 in total). I've managed to configure them but I had to skip some buttons like the P1 SELECT and START. I do however have them mapped for P2, and here's where my problem is. I can play games if I'm only playing with my P2 (which has all buttons mapped). Is that where the problem is?
      So my question is. Do you need to have every button mapped in order for the games to start?
        Zing Global moderator Translator @freddy00 last edited by
        @freddy00 As far as I know, games should start even though your controller is not working, are you sure you have not configured anything wrong?
        I do not use GPIO, I do not understand much, but, did you follow the manual?
        https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(EN)
        If the manual does not help you, I do not know much how to help you, but I recommend you make it clear what board you are using, what version of the recalbox, what you have modified, how you made the GPIO connections, because it is difficult to help without information.
        • freddy00
          @zing thanks for the quick response!
          I can't check all the details right now, but I downloaded the latest version from the official website and I'm using a Raspberry Pi 3.
          One thing I also didn't mention is that I didn't exactly follow the steps when configuring the pins and what not. Originally I downloaded retropie so I wired my joystick and buttons after another GPIO configuration. For example my P1 Joystick UP is wired to the "A" button. Do you suggest I rewire my GPIO completely since the main reason for games not starting is controller issues?
            @freddy00 I can not guarantee that the problem of the games does not start has direct relation with the configured GPIO wrong, but, since you are sure that this is wrong, I do not see why not to tidy up.
            My recommendation is to redo the GPIO following the manual, only then you will be sure if that is the problem, or if it is not.
            freddy00 1 Reply Last reply Reply Quote 1
            • freddy00
              freddy00 @Zing last edited by
              @zing I'll have a look and see if that's the issue.
              Right now I am able to load games with my P2 Joystick being selected as P1 in the configuration menu, and my P1 Joystick as P2. But when I load games with two players it comes up a yellow text at the bottom of the screen saying that GPIO controller 1 is not configured, so I'm guessing that has to be the issue.
