    Télécommande Amazon fire stick tv
    Media-center/Dualboot
    recalbox kodi amazon fire stick remote
    • madman03
      madman03 last edited by
      J'ai connecté ma télécommande Fire Stick TV sur mon raspberry pi 3b+ avec la version bêta de recalbox de février 2019.
      Elle fonctionne correctement avec emulation station mais lorsque je lance Kodi elle ne fonctionne pas.
      J'ai tenté le menu des manettes dans Kodi mais elle n'est pas listée.
      Quelqu'un a t'il réussi à l'utiliser ?
      Merci d'avance
      • max_downey
        max_downey last edited by
        Once you reset your Fire TV Stick to correct a problem, a potential new problem may spring up -- the Voice Remote does not work today. This means that you can't form the Wi-Fi details making your Fire TV Stick worthless. I can feel your own pain. Even I have faced many issues with my amazon firestick remote,So i found permanent solution to this problem by following the guidelines mentioned on howtotechh.com/amazon-fire-stick-remote-not-working/ .
        Remotes assist in browsing streaming apparatus such as Fire TV Stick. But, trouble begins brewing when they cease functioning.
        Does that mean that you won't ever have the ability to use your cherished Fire TV Stick back again? Nope. That is not the situation. You merely should repair the matter and set your Voice Remote properly along with your Fire TV Stick.
        Listed below are 9 methods which allow you to set your remote properly along with your Fire TV Stick following a factory reset.
        I knowI understand. You've only reset your Fire TV Stick, and today I am asking you to restart it. Well, that is how funny the world is! Restart resembles a sip of a magic potion.
        As soon as you're on the distant pairing display and it is not pairing, unplug the power supply of your Fire TV Stick to restart it. Subsequently replug it and try pairing the distant with the house button.
        Just as this seems, but sometimes the batteries of distant gets misaligned. Take the batteries out and keep them out for 10-20 minutes. Then place the batteries back properly and set it with the Fire TV Stick.
        1. CHANGE BATTERY
          Among the typical causes of Fire TV Stick distant not pairing before or after factory reset is really a dying battery. I recommended you add a fresh set of batteries to the remote.
        CLEAN BATTERY COMPARTMENT
        Oftentimes, rust or dirt within the battery compartment prevents it triggering the remote properly. You have to remove the bolts and wash both metal connectors using a tissue or clean fabric. Following that, insert the bolts and restart the Fire TV Stick by unplugging it. Then try pairing it with your own remote.
        Get near your TV and press the Home button on your Fire TV Stick distant for 20-40 minutes (or until you find the confirmation message) when requested to pair the distant. If both set , a confirmation message will show up in the bottom-right corner of this display.
        You may need to repeat the procedure if the pairing is not completed the very first time. Try it a few times before you get it done right.
        While the official means to pair a distant would be with the Home button, several users on several different forums have indicated that pressing on the play/pause button along with a mixture of pick (centre round button) along with Home button to get 40-60 minutes on the matching display did the trick for them.
        As dumb as it might sound, sometimes the buttons have been stuck and consequently, don't respond. So check if either of those buttons is not shining and try pairing it.
        Whenever you're pairing the distant, ensure that there is not any additional Fire TV Stick switched on close to you. If that is true, it may be interfering with the pairing procedure. Switch it off, then reboot your Fire TV Stick, and try pairing it with an remote with the house button.
        1. RESET REMOTE
          Using Fire TV Stick off, press on the menu (three pub ) button, back button, and the left key of this navigation ring at precisely the exact same time in your own remote for 10 minutes. Release the buttons and then twist onto the Fire TV Stick. Subsequently on the pairing display, set the remote simply by holding the house button to get 20-40 seconds.
