    Error on netplay
    netplay
    • Zyrh
      Zyrh last edited by Zyrh
      Hi all.
      I'm going to explain the configuration that I have at home, to see if anyone can offer any solution:
      I have two routers:
      • The first one, from my Internet company, with the private IP 192.168.1.1, with DMZ to the second router
      • The second one, an Asus, private IP 192.168.1.2 in the WAN connection (this is where the DMZ of the router 1 points) and the private IP 192.168.2.1 for the LAN.
      I have configured the port redirection on both routers:
      Router 1: alt text
      As you can see, the port redirection goes to WAN interface of router 2 (this is because the DMZ for some weird reason did not pass that port)
      Router 2: alt text
      Directs the port to the IP of the Raspi (which is a static IP)
      Well, at this point, if I try to join a game in netplay, it shows "It has been correctly mapped the ports in 192.168.1.2:55435) and shortly after I get a message of" Failed to initialize Network" and quick me off.
      I had to configure the redirection rule in router 1 cause without it I always failed to map the ports (mesage right after join an online game)
      Upnp is active on both routers.
      Son, I don't get why this is not working.
      Any idea?
      Raspberry Pi model: Raspberry 3B +
      Recalbox version (build): February 2019 Beta Version
      Hardware (Micro SD, power supply, etc.): Micro SD Samsung Evo Plus 32 GB, Raspberry power supply 9098126
        Zing Global moderator Translator @Zyrh last edited by
        @zyrh Did you follow the Wiki instructions?
        https://github.com/recalbox/recalbox-os/wiki/Netplay-Guide-(EN)
