    Latte Panda issue
    Emulator Arcade/PC/Console
    latte panda issue
    • pawaller
      pawaller last edited by
      Hi,
      Has anyone had any success in running on Latte Panda?
      I'm using the Generic x86 build.
      I see the boot spash screen but then nothing.
      I can SSH into the box OK.
      I had a similar issue when trying to run Lakka on this board.
      In order to get Lakka working I had to modify a config line with VIDEO_MONITOR_INDEX=1 but I don't know what/where to find this or a similar setting.
      When I run xrandr it says my display is DSI1
      Any ideas please?
      Many thanks
      Phil
      voljega strodown 2 Replies Last reply Reply Quote 1
        voljega Banned @pawaller last edited by
        @pawaller afaik you're the first one to use this board with Recalbox. Did you try the beta version ? It's much better with x86 boards.
        In which file did you try to add this line in Retropie ?
        @strodown might be able to help you
        • strodown
          strodown @pawaller last edited by
          @pawaller hi you can give me the result of the dmesg command and the xrandr command
          copy paste the result into a pastebin page please
          Recalbox X86_64 :
          X-Arcade
          Lightgun Mayflash Dolphin-bar
          • pawaller
            https://pastebin.com/Gevhn2Zm
            Many thanks for your help
            Phil
            • strodown
              strodown last edited by strodown
              do the same with this command cat / var / log / Xorg.0.log
              if you can describe me a little better what happens at startup, can you choose between recalbox andrecalbox verboseat startup?
              which output do you want to use the output DSI1 or the output HDMI2?
              Recalbox X86_64 :
              X-Arcade
