    Solved Is it possible to add animated svg files to a theme ?
    Themes & Interface
    possible animated svg theme
    • Yseurk
      Yseurk last edited by
      Hello / Bonjour ๐Ÿ™‚
      I'm actually working on a project and I was wondering if it is possible to that.
      I know that we can animate svg files for web, I know that Recalbox use svg files for backgrounds. But don't know if it works on Recalbox.
      I'm actually trying to do this, but don't know if I have to change other things, and not just put the animated svg files
      as it is.
      Thanks you ! ๐Ÿ˜ƒ
        Zing Global moderator Translator @Yseurk last edited by
        @yseurk Hello!
        As far as I know, this is still not possible with Recalbox.
        Se a minha resposta foi รบtil, por favor, dรช um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
        • Yseurk
          Thanks for your reply !
          I spent lot of time on that haha, and I always had problem (like only black svg files on recalbox) and didn't succeeded to animate svg files on recalbox. So unfortunately, as you said, it seems that it's not possible.
          I looked about gif, and it's the same thing. Maybe in other updates, haha, should be really fun.
          Have a nice day ๐Ÿ™‚
          Copyright ยฉ 2021 recalbox.com
