    Change color for Retroarchivements?
    archivments
    • Querp
      Querp last edited by
      Can I change the color for Retroarchivements? The yellow makes them hard to read when playing Game Boy.
        OyyoDams Staff @Querp last edited by
        @querp You should ask to libretro team, we don't develop the emulator itself.
        • Tornelf
          Tornelf last edited by
          Hi you can change it from retraorch menu in "on screen display section" to choose the color tou need. Then you have to save your choice in system/config/retroarch emulatedstuff.cfg (snes.cfg for instance). It's in this file than you write overaly's path, change its size and adjust screen.
          Raspberry 4
          ODROID XU 4 avec ventilo bruyant
          Microsoft xbox 360 wireless pad
          Clavier Logitech k400
          RECALBOX 7.2
          1 Reply Last reply Reply Quote 5
