    PSX Tweaks
    psx tweaks
    • iwakun
      iwakun last edited by
      Hello, i read in retropie forum about the tweaks on PSX emulators Link: http://blog.petrockblock.com/forums/topic/psx-graphic-tweaks/ in this topic a member say: [code]if you press select + Y (or X, not sure), you should get the retroarch menu. within that you can set a couple of options that increase the resolution of PSX games – they’re in the ‘core options’ menu, which is behind the ‘settings’ or ‘quick menu’ i think. they’re called ‘enhanced resolution’ or something like that.[/code] In Recalbox the select button is for reboot or shutdown, have a file to change the settings ? or how to do this on recalbox ? thank you for read !!
        Hello sorry i speak english not very well, but i think read manuel https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#recalbox-33x Special Commands: https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)#b---special-commands
        In game Press Hotkey on the controller and one of the following: R2 → Next shader preset L2 → Previous shader preset
        You can access retroarch configuration menu with Hotkey + B If you want to configure retroarch and save the config, you can select the "Save Settings on Exit" in the retroarch menu. After that, all configuration you make in rgui will be saved.
