    Solved No Dreamcast rom folder on latest beta build
    dreamcast rom latest beta build
    • Sauromayne
      Sauromayne last edited by
      I just installed the latest beta build and there is no dreamcast folder in the share/roms directory. Is there an extra step I need to do to install Dreamcast? I tried googling the issue and didn't come up with much.
        @Sauromayne
        raspberry ? usb key storage ?
        Sauromayne 1 Reply Last reply Reply Quote 0
        • Sauromayne
          Sauromayne @acris last edited by
          @acris Oops sorry I forgot to mention I am using an Odroid C2. Would USB key storage mean I am using a usb drive for storing my roms? Currently I am using the internal micro SD recalbox is installed on. Should I use a usb drive instead? I have a couple 32GB sandisk cruzer glides. If those aren't good to use I can get something at the store tomorrow if someone can suggest me a good usb to get.
            @Sauromayne
            dreamcast it's not compatible with odroid C2,
            it is not powerful enough
            if a folder does not appear is that it is not compatible
            https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
            • Sauromayne
              @acris Okay that makes sense thank you for the info!
