    Bluetooth GamePad sensitivity
    GamePad/GPIO/USB encoder
    bluetooth gamepad sensitivity
    • lhari84
      lhari84 last edited by
      Re: General Bluetooth GamePad sensitivity
      I want to post some discovery I have made regarding the old issue above:
      When I switched beetween differnent Bluetooth dongles for testing, I found out that the (too) high sensitivity seems only to be present with Broadcom-based Bluetooth controllers. Both tested internal Pi3 and external Asus Dongle are much too sensitive and both are Broadcom based.
      When I use a Digitus Dongle, which is using a CSR chipset, it's fine - no more problems of steering much too heavy at Mario Kart for example!! 🙂
      Further it doesn't matter which GamePad I use, PS4 DualShock, various 8Bitdo controllers,... It really seems to be the Chipset on Pi-side.
      Can anybody confirm?
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
      • lhari84
        I want to announce that problem is also gone with latest beta. Tried with internal Bluetooth of Raspberry Pi 3 B+ (Broadcom) and works fine there.
        Pi 4:
        Pi Zero 2W:
