    General Bluetooth GamePad sensitivity
    GamePad/GPIO/USB encoder
    general bluetooth gamepad sensitivity
    2667
    • lhari84
      lhari84 last edited by
      I'm wondering why I haven't found a (dedicated) topic for this issue, so I start a new one:
      Is there a chance to configure sensibility of D-Pad and Analog-Sticks, globally for any connected Bluetooth GamePad?
      In my and also some friends' point of view, even games in different emulators react too sensitive on both D-Pad and Analog-Stick inputs.
      Examples:
      • Steering with D-Pad in well known SNES kart racing game is very tricky, same in in N64 version with Analog-Stick. The vehicles often take the corner much more far than we wanted - and than we expected - because we know the original console's behavoir.
      • Same for example with shooters on PSX, no chance to point exactly on an enemy because Analog-Stick is so extremely sensitive.
      It's not just my config, I've seen this on other Recalboxes of friends too. I'm using 1 PS4 GamePad and 1 8bitdo NES30 Pro GamePad on latest 4.1 stable. But Problem also seen already with PS3 GamePad on 4.1 unstable a year ago.
      Can't tell if wired controllers are affected too, we all use and use and have BT-controllers only.
      Thank you very much in advance for your suggestions.
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
        Substring @lhari84 last edited by
        @lhari84 snes never had analog inputs !
        For n64, you can configure the deadzone
        Psx : i thinknthe pad is not set as analog in retroarch
        lhari84 2 Replies Last reply Reply Quote 0
        • lhari84
          lhari84 @Substring last edited by
          @substring
          Thanks I'll try to find the settings you suggested and modify them.
          Regarding SNES, that's why I have written I have same problem but with D-Pad there 😉
          Pi 4:
          Pi Zero 2W:
          • lhari84
            @substring
            The thing with the D-Pad is quite strange anyway. In my understanding, as it's called "Digital"-Pad, it only knows "button pushed" or "button NOT pushed". How the h*** can it be that it's too sensitive? 😄
            Maybe some input lag when releasing the button...? But on the other hand response times seem quite good, at least since I use an external BT-dongle instead of the Pi3's internal bluetooth.
            Pi 4:
            Pi Zero 2W:
              @lhari84 my bad XD
              Input lag i guess. Sharpen your reflexes, time to open your 3rd eye and improve your foreseeing skills ^^
              lhari84 1 Reply Last reply Reply Quote 0
              • lhari84
                @substring
                I will ^^
                Pi 4:
                Pi Zero 2W:
                • rezahaghi321
                  rezahaghi321 Banned last edited by
                  This post is deleted!
