    SCPlayer / ALSA Drivers
    controller ps3 голосовые поздр alsa spotify scplayer
    • noobfire
      noobfire last edited by
      Hey! I'm using my Raspberry Pi with Recalbox OS as my only OS because I find the combo of Kodi/Emulationstation very convenient. I want to use Kodi for handy Spotify playback so I'm interested in SCPlayer. Its a Java Addon which enables the use of Spotify Connect, so you just easily can use your phone to directly stream content on-the-fly on your Raspberry Pi. https://github.com/crsmoro/scplayer/tree/master Everything in the tutorial/how-to worked perfectly and I even can login via the webinterface and control everything as it should work. The problem however is the actual audio playback. The instructions tell that you have to use
      echo snd_bcm2835 >> /storage/.config/modules-load.d/audio.conf
      on OpenELEC and sudo modprobe snd_bcm2835 on OSCM. Those commands are there to load ALSA sound drivers that are needed to do the audio playback. None of them worked however, altough there actually seems to be a lot of content of ALSA already installed (amixer, several ALSA directiories, etc.). I really want to use Recalbox for everything and dont want to use Dualboot, even tough stuff like that should be far easier on openELEC or Raspbian I assume.. Is there a easy way to enable ALSA drivers or am I simply missing some easy command perhaps?
      • digitaLumberjack
        Hi, the driver is already loaded on recalbox... It is not a driver, it's compiled directly in the kernel.
        • noobfire
          Okay, well.. But I cant hear anything when I'm playing a song with SCPlayer..
          • Pablo Macaluso
            Pablo Macaluso last edited by
            This still works?
