    Solved Web-Manager not working in 4.1 stable
    web-manager 4.1 stable
    • lhari84
      lhari84 last edited by
      Hi,
      I'm using latest 4.1 stable (18.07.13) and Web-Manager is not available at http://"recalbox-ip"
      I want to mention that I have system security enabled. This was also the only hint I have found in wikis and forum yet: Maybe web-server was bricked by system security in the past? But should work in the meanwhile, right?
      And also when I disable system security, after the reboot Web-Manager is still not available.
      In recalbox.conf Web-Manager is on and also disabling and enabling it again in Emulationstation GUI doesn't help.
      Do you have any idea what I can do? I have basic linux know-how, so I can also run SSH, run scripts, etc. if needed.
      Many thanks in advance!
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
        OyyoDams Staff @lhari84 last edited by
        @lhari84 Please disable security, it's bugged and has to be fixed.
        lhari84 1 Reply Last reply Reply Quote 1
        • lhari84
          lhari84 @OyyoDams last edited by
          @oyyodams Ok, for now it was working fine for me... -> Till I needed Web-Manager 🙂
          Problem is, that Web-Manager still seems to be bricked after disabling security. So only way to fix is a fresh clean installation of Recalbox?
          Pi 4:
          Pi Zero 2W:
          • lhari84
            So I'll live without Web-Manager for now... I'll do a clean installation when Recalbox Pi3 B+ version is out and hope security won't destroy Web-Manager anymore.
            I'll mark topic as solved.
            Pi 4:
            Pi Zero 2W:
