    Recalbox and config.txt
    recalbox config.txt
    • x520
      x520 last edited by
      Where is config.txt in Recalbox ?
      I need change resolution screen:
      1280x720 to 1216x684 (64/2, 36/2)
      overscan_left=32
      overscan_right=32
      overscan_top=18
      overscan_bottom=18
      Jearon 1 Reply Last reply Reply Quote 0
      • Jearon
        Jearon @x520 last edited by Jearon
        @x520 hello! That depend on your installation type. Are your Roms installed on a USB key or all of your Recalbox system is on your micro USB card? In the first case the config.txt is on the root of the micro usb's visible partition. In the second case... mmmh I don't know i ve done this configuration 😛 but i think that it's at thé same place.
        RPi3 B + boîtier Nespicase + et Recalbox 9 - Manette Xbox360 filaire + clavier Rii mini i24T + noname type Snes
