    Two Xbox 360 Controller
    adaptateur mane
    2178
    • mobkrieger
      mobkrieger last edited by
      Hi guys I have two xbox 360 controller (a wireless one and a wired one). The Problem is that i can just use one at a time. So for example if I wanna play a Mario Kart N64 2 player game only one Contorller works. Both Controller are configured in the setupmenu and dedicated. Can someone help me? Sorry for the english Greetings 🙂
      • digitaLumberjack
        Hi, there are many issues with the xbox controllers. I'm trying to make it work, but that could take some time.
        • mobkrieger
          in the meantime i tried some other USB Controller (Saitek and a PS3 controller) also with those controller i had the same issue ill just wait patiently for new changelogs thanks for your hard work 🙂 i know its a lot of work
          • digitaLumberjack
            Only on N64 ?
            • mobkrieger
              Sorry for the late answer yes its only in the N64 Emulator PSX for example is working without problems Greetings from Germany 🙂
              • digitaLumberjack
                Ok it's related to mupen64 because it's in beta support on recalbox, and we use the mupen64 auto config for controllers. I think you should take a look at mupen64 website for the configuration of 2 players.
