    Custom shaders: how to?
    shaders
    • Conte_Hamlin
      Conte_Hamlin last edited by
      Hi to all, i'm new to Recalbox (last version on the pi3) and i'm trying to add some custom shaders to my recalbox but i'm unable to find the folder where they are stored.
      The shaders .cfg files are stored in \RECALBOX\share\system\configs\shadersets and
      in my case the lines writted in the retro.cfg are pointing to a folder that i'm unable to find; for example:
      snes=/recalbox/share_init/shaders/crt-caligari_gamma_115.glslp
      if i go to my recalbox folder i can't find share_init and also any shader folder... so where are those .glslp files and the .glsl stored?
      That said and after: how to add a custom shader? After placed the glsl and glslp in the proper folder may i edit a new .cfg and put it in \RECALBOX\share\system\configs\shadersets so i can select my personal set directly in recalbox settings menu?
      Thank you!
        Zing Global moderator Translator @Conte_Hamlin last edited by
        @conte_hamlin Read this:
        https://github.com/recalbox/recalbox-os/wiki/Shaders-configuration-(EN)
        Conte_Hamlin 1 Reply Last reply Reply Quote 0
        • Conte_Hamlin
          Conte_Hamlin @Zing last edited by
          @zing
          Alreay checked, but in my case /recalbox/share_init/shaders/ doesn't exist in my recalbox folders...
            @conte_hamlin I have the impression you're looking for in the SHARE partition, and the manual talks about the RECALBOX partition, is not that the problem?
