    recalbox 18/07/13 pc x64 gamepad 360 configure
    GamePad/GPIO/USB encoder
    recalbox 180713 x64 gamepad 360
    • avb82
      avb82 last edited by
      Hey. can't figure out how to set up triggers in the system. I use a gamepad xbox 360.
      in settings: (main menu - controllers settings - configure a controller).
      the problem is that: triggers are defined as buttons
      games on dreamcast cannot be played. triggers should be defined as axes, then everything is fine.
      Please correct this. (or give instructions how to fix)
      happy nice day!
        voljega Banned @avb82 last edited by
        @avb82 no it's alright that triggers are defined as buttons L2 and R2. It's strange though that L1 and R1 don't appear in your screencap.
        However what do you mean when you say 'dreamcast can not be played' ? triggers do not work inside dreamcast games ?
        • avb82
          not. it is not right. triggers must be axes.
          Run Sega Dreamkast, any racing game. and you will understand. Triggers should work like pedals. push force response.
          (lakka, batocera linux - define correctly)
          same gamepad from ps3
          • avb82
            in the games, not calibrated.0_1540377094816_IMG-98819c34e3e07c3e6b77d0ae16043f8c-V.jpg
