    Bluetooth controler.
    MediaCenter & Dualboot
    bluetooth controler
    • Cristian Muñoz
      Cristian Muñoz last edited by
      I just installed the latest version of recalbox in raspberry pi3. But it comes with kodi 16. I do not longer have bluetooth controller compatibility. I need to use the keyboard to navigate. Is there any solution to upgrade the version. Kodi 17 was so fine 😕 even with my usb controller i can't get work. Only the keyboard works.
      • joinski
        joinski last edited by
        Just remap your controller, then it should work within kodi
        • Cristian Muñoz
          How do i remap? kodi 16 doesn't give me the option to config the controller. Just the option to check if i wanna use a controller 😞
          joinski 1 Reply Last reply Reply Quote 0
          • joinski
            joinski @Cristian Muñoz last edited by
            @cristian-muñoz
            not in kodi, in ES menu (main Menu, when recalbox starts)
