    recover \boot\config.txt after unsucess overclock
    recover bootconfig.txt unsucess overclock
    • Marcos
      Marcos last edited by
      Hi, I tried to overclock and now my raspberry pi 3 does not turn on, it goes without signal, I tried to access the network to change the settings but I can not, when accessing the sd card through linux in the boot folder only a .keep file appears, there is some form of to change the wrong configuration I made in the \ boot \ config.txt file without having to reinstall everything and lose all my settings?
      • Gaetan
        Gaetan Theme moderator @Marcos last edited by
        @marcos Yes, you can undo the overclock in the config.txt
        Marcos 1 Reply Last reply Reply Quote 0
        • Marcos
          Marcos @Gaetan last edited by
          @gaetan I can't acess config.txt
          • Gaetan
            @marcos even when you put your sd card information your pc ?
            • Marcos
              @gaetan yes but /boot folder dont show files
