    PSX Aladdin the Nasira Revenge - Bugged textures
    Emulator Arcade/PC/Console
    psx
    • cedric85
      cedric85 last edited by
      Hi 🙂
      I use PSX to launch ps1 games (Epsx doesn't run on my little computer and it is difficult for me to install all the pluging required), it works well except for the game Aladdin The Nasira Revenge.
      Indeed, the game doesn't run properly : the textures near the character are bugged (all ok for the decor which is further). It appears as and when I move the character. Here is a screen of the problem :
      I tried some different configuration (default config and its opposite) :
      But it doesn't change anything about the bug...
      I tried with two download ROM sources.
      Do you have any idea to help me to fix it ? Thank you !
        Hello
        it's recalbox 's forum here, not for standalone emulator.
        use google search to find help with your problem on emulator computer.
