    Black Screen while setting up controller
    while setting
    • atl13
      atl13 last edited by
      Hi, I have Recalbox installed on a Pi 3 with multiple other OSes via Noobs. Everything else works fine except Retropie. It boots and immediately after booting is asks to set up a controller. I have tried with two wired controllers and a bluetooth keyboard and it always goes to the black screen that has the date and time on the lower left and the Retropie logo and it just hangs. This happens while I am trying to map the buttons, at random times, sometimes while setting the first button. I have tried using only one device plugged in (the controller or the keyboard). Whatever I do the same things happens and there is no way to revert from it except restart which means unplugging it (since i am using the original Pi power cable). I have seen a variant of this in this thread here https://forum.recalbox.com/topic/14977/black-screen-error that also has a photo of how the black screen looks. There has been no solution for this. I hope someone can give some insight or otherwise I will be forced to remove it since it is completely unusable.
      • Gaetan
        Gaetan Theme moderator @atl13 last edited by
        Hi @atl13, it's not really clear, do you talk about retropie or Recalbox issues ?
        Because if it's retropie, you should ask them directly.
