    Keep new package through updates
    transmission buildroot updates
    • lopezishere
      lopezishere last edited by
      Hello all, I just finished compiling recalbox following the wiki instructions. I did it in order to include the transmission package on the final build, as I would like to download torrents with my rpi2 and recalbox. My question is, once i install this "modified" recalbox, will the transmission package be kept over next updates, or will it be deleted on next update if I update recalbox using the option from Menu/System? I tried to find a similar topic on the forum and wiki but couldn't find any help. Thank you!
      • digitaLumberjack
        Hi, updates only updates the existing files in recalbox. So it will update es if you made modifications, but not new files you created with your buildroot packages 🙂
        • lopezishere
          Perfect!!! I will try to install it today to make this one my definitive rpi2 operating system. Thank you! 🙂
