    trouble with roms after following bezel tutu
    trouble roms following bezel tutu
    • benbb
      benbb last edited by
      I followed the guide 'tutu 20', and after this roms in all systems except for N64 will not load, they just take me back to ES, any help much appreciated
      tail -100 /recalbox/share/system/logs/recalbox.log
      [ 14.06] Updating /recalbox/share/system/.emulationstation/es_input.cfg for deviceName="Microsoft X-Box 360 pad" deviceGUID="030000005e0400008e02000014010000"
      [ 14.18] Couldn't upgrade es_input.cfg for deviceName="Microsoft X-Box 360 pad" deviceGUID="030000005e0400008e02000014010000"
      [ 14.20] ---- recalbox-config.sh ----
      [ 14.23] Updating /recalbox/share/system/.emulationstation/es_input.cfg for deviceName="Xbox 360 Wireless Receiver (XBOX)" deviceGUID="030000005e040000a102000007010000"
      [ 14.29] Couldn't upgrade es_input.cfg for deviceName="Xbox 360 Wireless Receiver (XBOX)" deviceGUID="030000005e040000a102000007010000"
      [ 14.31] ---- recalbox-config.sh ----
      [ 14.34] Updating /recalbox/share/system/.emulationstation/es_input.cfg for deviceName="Xbox 360 Wireless Receiver" deviceGUID="030000005e0400001907000000010000"
      [ 14.40] Couldn't upgrade es_input.cfg for deviceName="Xbox 360 Wireless Receiver" deviceGUID="030000005e0400001907000000010000"
      [ 14.64] Will not start S13fbcp : system.fbcp.enabled is set to 0
      [ 14.92] starting new log
      [ 14.94] converting dos to unix carriage return characters
      [ 15.24] setting hostname to RECALBOX
      [ 15.26] setting timezone to Europe/London
      [ 15.27] setting audio volume to 97
      [ 15.37] ---- recalbox-config.sh ----
      [ 15.40] setting keyboard layout to en
      [ 15.42] updated wifi settings : ssid=
      [ 15.43] setting audio volume : 97
      [ 15.49] updated wifi settings : ssid=BTHub6-HWP5
      [ 15.50] Simple mixer control 'PCM',0
      [ 15.51] cannot open file en
      [ 15.52] Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      [ 15.52] Setting volume for numid=3
      [ 15.53] Playback channels: Mono
      [ 15.54] Limits: Playback -10239 - 400
      [ 15.54] Setting volume for numid=2
      [ 15.55] Mono: Playback 0 [96%] [0.00dB] [on]
      [ 15.57] Setting volume for numid=1
      [ 15.59] Setting volume for numid=5
      [ 15.60] amixer: Control default element write error: Operation not permitted
      [ 15.61] Setting volume for numid=4
      [ 15.62]
      [ 15.63] Restoring ALSA mixers configuration
      [ 15.85] setting audio to auto
      [ 15.88] ---- recalbox-config.sh ----
      [ 15.90] setting audio output mode : auto
      [ 15.92] numid=3,iface=MIXER,name='PCM Playback Route'
      [ 15.93] ; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
      [ 15.94] : values=0
      [ 16.27] starting emulationstation with lang = en_US
      [ 16.95] ---- recalbox-config.sh ----
      [ 19.69] Starting S92switch
      [ 19.72] script /recalbox/scripts/powerswitch.sh [ STARTED ]
      [ 20.92] Starting S94manager
      [ 21.15] ... Starting manager v2
      [ 24.18] starting xarcade2jstick
      [ 24.34] xarcade2jstick : no official stick found, looking for keyboard encoder now ...
      [ 487.15] Stopping S94manager
      [ 487.36] Stopping S92switch
      [ 487.38] script /recalbox/scripts/powerswitch.sh already stopped !
      [ 488.15] Stopping Emulationstation
      [ 488.20] Saving ALSA mixers configuration
      [ 488.47] Stopping S13fbcp
      [ 488.60] recalbox.conf saved to /boot partition
      [ 1.61] Let's play the video for 20 seconds
      [ 3.18] Wifi option enabled, trying to configure
      [ 3.24] Recovering wifi for SSID: BTHub6-HWP5
      [ 4.27] Wifi region: US
      [ 9.71] No need to upgrade configuration files
      [ 10.17] Will not start S13fbcp : system.fbcp.enabled is set to 0
      [ 10.46] starting new log
      [ 10.48] converting dos to unix carriage return characters
      [ 10.75] setting audio volume to 97
      [ 10.86] setting timezone to Europe/London
      [ 10.89] ---- recalbox-config.sh ----
      [ 10.90] setting hostname to RECALBOX
      [ 10.96] setting audio volume : 97
      [ 10.98] setting keyboard layout to en
      [ 11.02] updated wifi settings : ssid=
      [ 11.05] updated wifi settings : ssid=
      [ 11.07] Simple mixer control 'PCM',0
      [ 11.09] updated wifi settings : ssid=BTHub6-HWP5
      [ 11.09] Setting volume for numid=3
      [ 11.09] cannot open file en
      [ 11.10] Capabilities: pvolume pvolume-joined pswitch pswitch-joined
      [ 11.12] Playback channels: Mono
      [ 11.12] Setting volume for numid=2
      [ 11.13] Limits: Playback -10239 - 400
      [ 11.15] Mono: Playback 0 [96%] [0.00dB] [on]
      [ 11.15] Setting volume for numid=1
      [ 11.17] Setting volume for numid=5
      [ 11.19] amixer: Control default element write error: Operation not permitted
      [ 11.20] Setting volume for numid=4
      [ 11.20]
      [ 11.22] Restoring ALSA mixers configuration
      [ 11.43] setting audio to auto
      [ 11.46] ---- recalbox-config.sh ----
      [ 11.48] setting audio output mode : auto
      [ 11.51] numid=3,iface=MIXER,name='PCM Playback Route'
      [ 11.52] ; type=INTEGER,access=rw------,values=1,min=0,max=2,step=0
      [ 11.53] : values=0
      [ 11.88] starting emulationstation with lang = en_US
      [ 12.64] ---- recalbox-config.sh ----
      [ 15.46] Starting S92switch
      [ 15.55] script /recalbox/scripts/powerswitch.sh [ STARTED ]
      [ 16.77] Starting S94manager
      [ 17.02] ... Starting manager v2
      [ 19.94] starting xarcade2jstick
      [ 20.06] xarcade2jstick : no official stick found, looking for keyboard encoder now ...
      benbb 1 Reply Last reply Reply Quote 0
      • benbb
        benbb @benbb last edited by
        I have removed the files from the bezel tutorial bu still all my roms no longer work other than N64, can anyone please help?
        here is the support script:
        https://file.ac/b2hYy7Z2M7U/
        thanks, Ben
