    Problem connecting to a network share containing spaces in path
    connecting network share containing spaces
    • JacksonV1lle
      JacksonV1lle last edited by
      Hi there,
      I am having trouble getting Recalbox to connect to my network share because it has spaces in the path. I have tried the following but no luck:
      • 192.168.1.8:/Seagate Expansion Drive/roms
      • 192.168.1.8:/Seagate\ Expansion\ Drive/roms
      • 192.168.1.8:/Seagate\040Expansion\040Drive/roms
      • 192.168.1.8:/Seagate%20Expansion%20Drive/roms
      As a test, I have been able to set this up with a different network share on the same NAS device using a path without spaces.
      Can anybody help?
        OyyoDams Staff @JacksonV1lle last edited by
        @jacksonv1lle I'll investigate. As a quick fix for now, can you rename your network share and remove spaces ?
        JacksonV1lle 1 Reply Last reply Reply Quote 1
        • JacksonV1lle
          JacksonV1lle @OyyoDams last edited by
          @oyyodams Thanks. I have added a new share to my samba config without the spaces. It should be alright.
