    Hotkey with a PS3 Controller
    hotkey ps3
    • anthonyjclarke
      anthonyjclarke last edited by
      Hi PS3 Controller all working (yay!). Is there a preset "hotkey"? Do you have any suggestions as to what works best? Thanks
      • digitaLumberjack
        The preconfigured hotkey is the Home button. That allow you to quit with Home+Start, and you can use select for coins in mame4all (there is a bug where you can't add credit on certain games if select is the hotkey) The common rule for the hotkey is to use an unmapped button, or Select.
