    Solved No Wi-Fi network on a PI 2 Model B
    wi-fi network model
    2489
    • MorgothSauron
      MorgothSauron last edited by MorgothSauron
      • I'm using a Pi 2 (Model B) with latest Recalbox installed (18.07.13). Ethernet network is working, but not Wi-Fi
      • Wi-Fi network settings:
        • SSID visible ? Yes
        • Chanel: 3
        • WPA2-PSK/AES
      • recalbox network Interfaces without the Wi-Fi dongle
      $ ip a
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1
          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
          inet 127.0.0.1/8 scope host lo
             valid_lft forever preferred_lft forever
          inet6 ::1/128 scope host
      2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP8000> mtu 1500 qdisc pfifo_fast qlen 1000
          link/ether b8:27:eb:a0:d9:77 brd ff:ff:ff:ff:ff:ff
          inet 192.168.0.11/24 brd 192.168.0.255 scope global eth0
          inet6 fe80::ba27:ebff:fea0:d977/64 scope link
      • I configure Wi-Fi directly in recalbox.conf.
      $ grep wifi recalbox.conf
      ##Activate wifi (0,1)
      wifi.enabled=1
      ##Set wifi region
      wifi.region=FR
      wifi.ssid=le-wifi-de-morgoth
      wifi.key=enc:U2FsdGVkX1/fU30c3mVxGS0ngl1HclFBOFv9Y1qPFFU=
      #secondary wifi (not configurable via the user interface)
      ;wifi2.ssid=new ssid
      ;wifi2.key=new key
      #third wifi (not configurable via the user interface)
      ;wifi3.ssid=new ssid
      ;wifi3.key=new key
      • Here's the output of dmesg after connecting Wi-Fi dongle
      [  350.254751] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
      [  350.356247] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8176
      [  350.356262] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [  350.356272] usb 1-1.2: Product: 802.11n WLAN Adapter
      [  350.356281] usb 1-1.2: Manufacturer: Realtek
      [  350.356290] usb 1-1.2: SerialNumber: 00e04c000001
      [  350.525195] usbcore: registered new interface driver rtl8192cu
      • A new network interfaces (wlan0) is added but no IP assigned
      $ ip a
      3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop qlen 1000
          link/ether 40:a5:ef:0e:dc:e5 brd ff:ff:ff:ff:ff:ff
      • I reconfigured the wifi.key with clear text value before rebooting. Still no Wi-Fi after reboot. No problem with this hardware configuration when running raspbian.
      • Let me know if you need the complete dmesg output after rebooting the recalbox with the Wi-Fi dongle pluged-in.
      • Any idea ?
      MorgothSauron 1 Reply Last reply Reply Quote 0
      • MorgothSauron
        MorgothSauron @MorgothSauron last edited by
        I did an additional test. I'm able to perform a Wi-Fi network scan. My SSID is in the list.
        $ iw dev wlan0 scan | grep SSID
                SSID: FreeWifi
                SSID: FreeWifi_secure
                SSID: le-wifi-de-morgoth
                SSID: FreeWifi
                SSID: Livebox-DE81
                SSID: zita
                SSID: FreeboxNanou14
                SSID: orange
                SSID: Freebox-0C6228
        So the Wi-Fi dongle seems to work properly. The question is why there is no IP assigned to the wlan0 interface ?
          OyyoDams Staff @MorgothSauron last edited by
          @morgothsauron tu as quoi comme dongle ?
          • MorgothSauron
            MorgothSauron @OyyoDams last edited by
            @oyyodams C'est un "Comfast" cf-wu810n acheté sur KUBII. Je sais qu'il n'est pas dans la liste des dongle compatibles, mais il fonctionne sans problème avec raspbian.
              @morgothsauron wai mais raspbian n'est pas Recalbox.
              On ne l'a pas testé: https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
              Je te conseille celui du recalstore.
              MorgothSauron 1 Reply Last reply Reply Quote 1
              • MorgothSauron
                MorgothSauron @OyyoDams last edited by MorgothSauron
                @oyyodams Je sais que recalbox et raspbian sont différents. Je voulais vérifier sur le forum s'il n'y aurait pas une astuce pour faire fonctionner le wifi. Je vais commander le Edimax EW-7811Un. Merci
                • MorgothSauron
                  Ca y'est j'ai recu mon dongle Edimax EW-7811Un et ça fonctionne 🙂
                  Mon interface Wi-Fi a une adresse IP:
                  $ ip a
                  2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP8000> mtu 1500 qdisc pfifo_fast qlen 1000
                  3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP8000> mtu 1500 qdisc mq qlen 1000
                      link/ether 74:da:38:eb:4a:15 brd ff:ff:ff:ff:ff:ff
                      inet 192.168.0.11/24 brd 192.168.0.255 scope global wlan0
                      inet6 fe80::76da:38ff:feeb:4a15/64 scope link
                  Et je peux downloadé un fichier de test:
                  $ wget -O /dev/null http://speedtest.wdc01.softlayer.com/downloads/test10.zip
                  --2018-08-05 20:11:34--  http://speedtest.wdc01.softlayer.com/downloads/test10.zip
                  Resolving speedtest.wdc01.softlayer.com (speedtest.wdc01.softlayer.com)... 208.43.102.250, 2607:f0d0:3001:78::2
                  Connecting to speedtest.wdc01.softlayer.com (speedtest.wdc01.softlayer.com)|208.43.102.250|:80... connected.
                  HTTP request sent, awaiting response... 200 OK
                  Length: 11536384 (11M) [application/zip]
                  Saving to: '/dev/null'
                  /dev/null                     100%[=================================================>]  11.00M   601KB/s    in 20s
                  2018-08-05 20:11:55 (550 KB/s) - '/dev/null' saved [11536384/11536384]
                  Merci pour l'aide 🙂
