    Solved Start and Select crashes Recalbox
    update hotkey start select
    • tehDonkeyKong
      tehDonkeyKong last edited by
      Just applied an update this morning. Everything's great except when I use the hotkey (Start & Select) to back out of a game, it goes black. Have to power cycle every time I back out of a game. Suggestions?
      Version 18.07.13
        Zing Global moderator Translator @tehDonkeyKong last edited by
        @tehdonkeykong In which architecture are you having trouble? RPi3 / 2/1, PC 32/64?
        In the Main Menu go to "Controller Settings", "Configure A Controller" and then do the Button Mapping for your Controller.
        Also, it is not necessary to restart the system when it locks on a black screen, you can use the recalbox manager and restart the Emulationstation, most of the time that is enough, and faster.
        tehDonkeyKong 1 Reply Last reply Reply Quote 0
        • tehDonkeyKong
          tehDonkeyKong @Zing last edited by
          @zing Pi 3 Model B. I haven't tried re mapping the hotkey. Hopefully that would fix it.
          I may just re write to the micro SD card and run the update again.
            @tehdonkeykong Since you intend to rewrite the SD card, it is best to do a clean installation of the latest version, unfortunately this will force you to redo the settings you made, but it eliminates the possibility of having an error when updating.
            • tehDonkeyKong
              @zing Yeah a clean install did the trick. No issues whatsoever. Thanks!
