    GPIO not working in MAME?
    GamePad/GPIO/USB encoder
    gpio mame
    2151
    • tommymsw
      tommymsw last edited by
      So, I just did a fresh install to 4.1. I backed up my /roms folder and then moved it back to the new install (if that is important). But now MAME roms don't seem to work... Or at least the GPIO does not seem to work, but ONLY in MAME.
      Any idea where I should start problem solving?
        Substring @tommymsw last edited by
        @tommymsw gpio doesn't work ? Not at all ? Nondire tiin no button ? Or you haven't added a hotkey and can't insert coins ?
        tommymsw 1 Reply Last reply Reply Quote 0
        • tommymsw
          tommymsw @Substring last edited by
          @substring Does not work at ALL. I guess it could be that the ROMS are not working (my first thought), but then I noticed that they were all not working the same way (appear to be frozen), then I figured it must just be the GPIO not working. I have to reset the Pi to get out of mame. Hotkey also does not work. As if the GPIO is off when on mame.
            @tommymsw you're the only one complaining about this ... Do youhave some other pads plugged ?
            • tommymsw
              @substring Ok. I was hoping it was a common thing, like I had to set something special up in MAME. I will check my roms and see if maybe they are not the right ones for the new emulator?
              I have no other controllers plugged in. I will plug in a keyboard and see if that works. I just wanted to ask here fist in case it was a known and simple fix. 🙂
              Is it possible when I copied the /roms folder from the old system, that some MAME settings in there overwrote some new ones?
              • Dotto Raus
                Dotto Raus last edited by
                The same thing for me. "insert coin button is not working" Mame games are impossible to play even using key "5" of my keyboard.
                I thought with 13.07.18 update that issue was solved but nothing.
