    PS3 Controller - can't get it to work :(
    GamePad/GPIO/USB encoder
    ps3
    2401
    • james-lord
      james-lord last edited by
      I've tried 3 different bluetooth dongles and I'm getting similar result with all of them. reset PS3 controller with a pin, Install recalbox, boot it, with bluetooth dongle in the pi2, plug in the ps3 controller via USB, wait for 10 seconds then disconnect, press the PS button to connect. At that point it vibrates as though it had connected, but when I go to configure it it's not showing in the p1 controller nor recognised when I hold a button to configure it 😞 Am I doing something wrong? If not, can some one point me in the right direction for a (hopefully cheap) BT dongle that does work? is there a way to test via the command line? Thanks in advance
      • raulval82
        raulval82 last edited by
        Check this: https://github.com/digitalLumberjack/recalbox-os/issues/30 I had the same issue and was the bluetooth dongle.
        • james-lord
          Yeah, unfortunately I thought that was probably the case, which one did you have that worked? on checking it looks like all mine are CSR devices despite being different brands and are listed as not working 😞
          • digitaLumberjack
            You can try an other power suplly, a better one before buying a new bluetooth dongle. It worked for some people 🙂
            • james-lord
              Bad Bluetooth adapter: switching to a decent branded one has solved the problem 🙂 LOVING the work you're doing, it's awesome, as soon as I can I'll donate. One minor issue: has anyone got Super Mario World to work? I know the controllers are switched, but I can't get it to work
              • digitaLumberjack
                Hi James, Super Mario World works really well if you overclocked your rpi. Get a good rom. The controllers are inversed on Super Mario All Stars only.
                • james-lord
                  Sorry, I should have been clearer, the rom works perfectly, but I can't get the controller to work, even if I set p1 and p2 to use the same controller, I can't use the (now working (YAY!!)) ps3 controller to control the game, Zelda (for example) however works perfectly. Thanks for all the help so far 🙂
