    Solved ColecoVision Roms No Longer Listed With 18.4.20 Release
    Your recalbox
    colecovision roms longer listed 18.4.20
    • tdelios
      tdelios last edited by
      I had my ColecoVision games working prior to the latest release.. they are no longer listed in ES..
      How do I fix it?
        paradadf Staff @tdelios last edited by
        @tdelios check your roms have valid extensions, listed in the _readme.txt inside the colecovision roms folder. (Asumming you haven‘t modified anything else, specially the es_systems.cfg)
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @paradadf last edited by
          @paradadf .. I feel embarrassed... you are correct.. sorry for the bother..
